Trim AND Extend
Trim AND Extend
jp willm
Re: Trim AND Extend
Bruno
Hello
wonderful software. I'm using it currently in my designs.
Probably there are some tricks that I don't know yet.
I would suggest you some improvements.
1-The trim/extent command as the colleague mentioned above.
About trim command, please do the multiple selection. I don't know but it doesn't work inside this command.
2-I experienced some troubles moving/copying text. I'm using 2.2.0 alpha.
3-The possibility to use the window zoom inside a command.
4-Multiple style dimensions.
Thank you very much indeed
Wonderful work anyway.
Best Regards
Bruno
Bruno Zilli
Designer, CEng,
second level master in computational mechanics
NDT level 3
Re: Trim AND Extend
jp willm
Re: Trim AND Extend
fa201
You can use lengthen feature:
https://librecad.readthedocs.io/en/latest/ref/tools.html#modify
Fabrice
Re: Trim AND Extend
Bruno
In reply to this post by jp willm
bonjour M. Willms
moi aussi, j'utilise le 3D, et j'ai fait comme vous avez dit.
J'ai vu votres pages.
Vous avez fait un travail trés interessant avec Freecad.
Je vais l'utilizer dans la proxieme commande.
Merci.
Salutations
Bruno
Bruno Zilli
Designer, CEng,
NDT level 3
Re: Trim AND Extend
jp willm
