Trim a circle between two tangent lines
4 messages Options Options
CADExplorer
What technique can be used to trim a circle between two tangent lines as shown in the figure below?
Note that exploding the circle by using Tools -> Modify -> Explode will not work as the intersection points between the tangent lines and the control points of the circle do not align.
Re: Trim a circle between two tangent lines
Use Tools - Modify - Divide to cut up the circle at the intersection points with the tangents and then delete the unwanted part of the circle.
CADExplorer
In reply to this post by CADExplorer
Thanks, works great.
Please note, tangent point is always tricky. If it cannot find a tangent point as an intersection, try end points, etc.
