Trim two
Trim two
Bryon
Hello
Attempting to use Trim two. First limiting entry selects as it should. Second limiting entry selection causes both entities to lengthen. using 2.2 version.
Appreciate any thoughts.
Bryon
Re: Trim two
You are not asked for any limiting entity. It says: select first trim entity, select second trim entity. It works as it should.
Trim two
Bryon
Hi.
Trying to trim using two "limiting entities". The first selects normally. when i choose the second entity both entities "lengthen". Tried choosing both entities again to no avail. The manual only offers one way to trim using two "entities".
Thanks for any thoughts.
Bryon
Re: Trim two
There is no way to use two limiting entities. "Trim two" means to get two lines to meet. Or if they already have an intersection, then to let them end there. If you look at the prompt, it says "select first trim entity", "select second trim entity". No mention of a limiting entity.
