Trouble dimensining items
SupDoc
Whenever I use either vertical dimension or horizontal dimension. I get solid lines but no dimensions.. Can someone please give me fix for that?
Re: Trouble dimensining items
The dimension text and arrows probably are there, but very small. If you zoom in very close you will see them. That's a matter of the settings in Options - Current Drawing Preferences - Dimensions, together with units, intended scale and extent of the drawing. Not a short answer solution. You may provide a sample file here, so I can edit the settings for you to study, or dig into the manual to find out by your own.
