Undo in commandline in polyline possible bug
1 message Options
grypokx
i think typing "undo" in command line when undoing last polyline node is a bug.  The behavior is that it will undo not only the last polyline point but also the last command before the polyline command .
reprod:
1. create circle, create rectangle
2. issue a polyline command, then click to several points then type undo in command line.
notice that it will also undo the rectangle.
*undo works fine if you use the undo button in "tool options"
please delete if double post  or not in the right section
