Maybe the naming "start angle" and "end angle" is not optimal.
In DXF reference these values are named "parameter" instead of "angle".
Basically these values are angles, the range is from 0 to 2*PI, respective 0° to 360°.
The formula how start/end points are calculated, is explained in DXF reference too.
For details see
https://www.autodesk.com/techpubs/autocad/acad2000/dxf/ellipse_command39s_parameter_option_dxf_06.htmTherefor the angles match with the circular arc in the X/Y axes (0°, 90°, 180°, 270°), because in these corner cases one of the operands (sin(0°/180°), cos(90°/270°)) becomes 0.
A less mathematical explanation is this:
An ellipse is a distorted circle.
Draw a circle in the center of the ellipse with the radius of major axis.
Then construct the intersection of a 45° center ray with the circles circumference and draw a line parallel to the Y axis through the intersection point.
Where the vertical line intersects the ellipse is the calculated start/end point.
