Work-arounds
7 messages Options
mwh
Work-arounds
mwh
I'm using LibreCAD on a 64 bit Windows 7 computer.
I reported a cross hair issue about a week ago, after I had upgraded to LibreCAD 1.0.0rc2.
I don't know what the status of that issue is, but I found a work-around.
I copied the 1.0.0rc1 version of LibreCAD.exe into the rc2 installation folder and the cross hair problem went away.
And an added bonus is that the Help Manual works too, whereas it had not been working for me with the rc1 installation.
So at the present time, I have a LibreCAD 1.0.0rc2 installation with a 1.0.0rc1 version of LibreCAD.exe, with a cross hair that's back to normal and a working Help Manual.
mwh
Re: Work-arounds
mwh
I found another work-around for a layer issue I'm experiencing.
I created a template with several layers.
In addition to layer 0, I created:
1
Dimensions
HiddenLines
Text
But I found that each time I opened the drawing, the layer I created last (Text) was the one that was highlighted.
That's not the one I wanted to be highlighted.
I want layer 1 to be highlighted by default each time I open the drawing/template.
So what I did was delete layer 1 and then recreate it. Which means layer 1 is now the last layer I created and it's the one that is highlighted by default when I open the drawing.
Re: Work-arounds
mwh
Re: Work-arounds
mwh
Thanks, Ries.
Are you talking about the cross hair issue, the layer issue, or both?
mwh
Re: Work-arounds
mwh
R. van Twisk wrote
I will be releasing RC2 this week for windows because it was only windows that has the issue.
Ries
Will this be available at the normal Source Forge site or somewhere else?
Re: Work-arounds
Re: Work-arounds
In reply to this post by mwh
