after loading my dxf file is empty
6 messages Options Options
mkister
This post was updated on May 16, 2016; 10:31am.
Hello everybody. I´m new to librecad. Today i create a project. after saving the project i want to load it again. But even when i start librecad an open the file there is nothing to see from my project. only a black screen even i have noting done!
I tryed a new project and maked some lines. After that i saved it.
After closing and starting librecad and open the saved file. the screen is blank. no line is there!
I don´t understand it. What is my error?
Where is my project?
Can someone help please. Thank you.
I need my drawing back...
Re: after loading my dxf file is empty
Is it really empty? Try autozoom or doubleclick middle mousebutton / scroll wheel. Try select - select all. Check layers, visibility.
If this doesn't show up something I don't know, a specialist has to help.
In reply to this post by mkister
hi mkister,
please upload a test case dxf to show the issue.
mkister
Hello here the file.
The main problem is that even when i make a new file and save it after closing librecad and open the file there is no data shown...
When i open the same file with qcad the data is shown.
test2.dxf
Test file shows content ( triangle) on my pc in LC 2.09 and LC nightly on win with no problems.
mkister
I use mac...
I don´t understand this issue...
Perhaps i find a solution.
Thank you
