can the hatch entity refer the source entities and the hatch data?
isdsi
Re: can the hatch entity refer the source entities and the hatch data?
say, you have the same hatch pattern across many contours, and  you want to change angle of them all together.
I think you can edit properties one by one;
Since hatch is generated at run time, you can also choose your own custom pattern ( dxf files, see Edit -> Application Preferences -> Paths -> Hatch Patterns ).
1, set your hatch patterns, and copy patterns or create your own dxf files in this folder;
2, restart LibreCAD;
3, create hatches using the pattern just added;
4, you may use LibreCAD to edit the pattern file;
5, reload your dxf file contains hatches.
Then, the reloaded file should be using rotated pattern.
There could be better ways to do it though.
isdsi wrote
hello librecad team!.
please, let me show this image as below.
my english is poor. so i made this image.
in this time, the hatch entity have the hatch data. but can the hatch entity have the refer of the hatch data?
the picture says, if the hatch data is on somewhere and it is changed only one,
all of the hatch entity refer the hatch data will change at one time.
is it possible ? or is there something concept like this?
from isdsi.
