ctrl + click
ctrl + click
I've been thinking about possibilities for ctrl + click.
One idea is to have it activate "Deselect Intersected Entities" or "Deselect Window".
Re: ctrl + click
Now I'm thinking about two different selection modes.
The first mode is like we have it now,
where click and drag is "select window"
and ctrl + click would be "deselect window"
In the second mode click and drag is "select intersected entities",
and ctrl + click is "deselect intersected entities".
Re: ctrl + click
I think that's a good idea. The "default action" is an important feature indeed.
on selection actions, there's something to improve as well:
there's "select single", but no "de-select single";
there's "select contour", but no "de-select contour";
there's "select layer", but not "de-select layer";
For example, "select layer" action should be a "toggle layer", i.e., combination of "select layer" and "de-select layer".
Re: ctrl + click
What is the use case for "select contour"?
Re: ctrl + click
say, you have a perfect contour (like from: Draw -> Line -> Rectangle )
by "Select Contour" you can select the whole contour in one click, for hatching as a use case.
Re: ctrl + click
Ahh I see. Thanks!
