dev environment setup and usage
23 messages Options
12
Re: dev environment setup and usage
I eliminated some warnings;
all those remaining are the override warnings
which can be suppressed with -Wno-inconsistent-missing-override.
Also it turns out there is a button in Qt creator to suppress warnings (like CONFIG += warn_off);
it's the triangle with the exclamation point in the issues tab.
In reply to this post by DErik
Did you succeed in building with Qt Creator?
I wrote this more recently:
https://github.com/LibreCAD/LibreCAD/wiki/Becoming-a-developer
The only issue really is downloading xcode and running the commands to accept the license.
I would say it's worth the download, since building LibreCAD with clang takes about
3/8 the amount of time as with gcc; and no extra setup is required with Qt Creator.
12
