With the new CMakeLists.txt (librecad_lib), I can no longer build the Python extensions using swig. I always get undefined references. It worked before. Building works perfectly fine in librecad.pro. I have no idea what to do.
Let's merge your changes and fix the issue with the PR.
cmake-developer_old.patch
New CMakeLists.txt (not working) 1.) the builtin python needs "librecad" as name to be linked: set_property(TARGET librepython PROPERTY OUTPUT_NAME librecad) src in scripting module *.cpp (also used by *.pro building): PyMODINIT_FUNC PyInit__librecad(void); 2.) new methode in CMakeLists errors: pixi.error CMakeLists.txt |
Does this use any system python 3? Will that affect version used by users?
com to build:
git clone https://github.com/emanuel4you/LibreCAD.git cd LibreCAD git checkout developer (change to current CMakeLists.txt posted here) pixi run build |
this sould be fixed.
https://github.com/emanuel4you/LibreCAD/commit/7e457e6de1f5d77e94f2b8ca4094ef882564f613 but I still got an error using the "cmake -S . -B unix -DBUILD_TESTS=ON" test in build-all.yml result: cmake -- The C compiler identification is GNU 13.3.0 -- The CXX compiler identification is GNU 13.3.0 -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: /usr/bin/cc - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: /usr/bin/c++ - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Performing Test CMAKE_HAVE_LIBC_PTHREAD -- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success -- Found Threads: TRUE -- Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so -- Found WrapOpenGL: TRUE -- Could NOT find XKB (missing: XKB_LIBRARY XKB_INCLUDE_DIR) (Required is at least version "0.5.0") -- Found WrapVulkanHeaders: /usr/include -- Performing Test HAVE_STDATOMIC -- Performing Test HAVE_STDATOMIC - Success -- Found WrapAtomic: TRUE CMake Warning (dev) at CMakeLists.txt:24 (find_package): Policy CMP0167 is not set: The FindBoost module is removed. Run "cmake --help-policy CMP0167" for policy details. Use the cmake_policy command to set the policy and suppress this warning. This warning is for project developers. Use -Wno-dev to suppress it. -- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.83.0/BoostConfig.cmake (found version "1.83.0") -- Found Freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so (found version "2.13.2") -- Found Python3: /usr/bin/python3.12 (found version "3.12.3") found components: Interpreter Development Development.Module Development.Embed -- Found SWIG: /usr/bin/swig4.0 (found suitable version "4.2.0", minimum required is "4") found components: python CMake Error at CMakeLists.txt:1855 (add_subdirectory): The source directory /home/runner/work/LibreCAD/LibreCAD/externals/Catch2 does not contain a CMakeLists.txt file. |
I separated most part of librecad into a librecad_lib, and it's shared by the librecad executible and the unit test executible . The motivation is to be certain that the same code is tested.
The changed caused quite a few issues, but the change appears to be in the right direction.
What I find strange is that this Cache2 test isn't working on the developer GitHub repository. I haven't changed anything in the external/cache2 directory. It works fine on the master repository. And there's no CMakeFiles.txt file there, is there?
