hatching a area made by a polyline and two enclosed polylines
julienmorand2@gmail.com
Hello everyone,
I just moved to libreCAD. i was using before Qcad and autoCAD. I would like to make a solid hatch on a cross-section. My Area is made by a rectangle (with fillet) and inside this rectangle two smaller rectangles. When I try to fill it, Not all the surface is filled (see attached .png).
How can I do it?
Thank you
Re: hatching a area made by a polyline and two enclosed polylines
I could reproduce this behavior. It works well with normal hatches, but if you change to solid you get weird results. LC's hatching operations are known to be a weak spot.
