hatching is neither displayed in the pdf nor in the printout
8 messages Options Options
rudi72
LibreCAD 2.1.3 Schraffur ist nicht im PDF oder Print.
rudi72
Wie schon gesagt, zeigt LC 2.1.3 die Schraffur ansi31 auf dem Bildschirm und in der Druckvorschau an, aber nicht in der PDF oder auf dem Ausdruck.
Re: LibreCAD 2.1.3 Schraffur ist nicht im PDF oder Print.
Linewidth 0?
You may provide a sample file here.
rudi72
This post was updated on May 25, 2022; 10:56pm.
Here i send you my drawing
It is as I suspected. The hatching's line width is "by layer", and the layer's pen setting is 0.00 mm.
Depending on the printer and the pdf-viewer this can result in the lines indeed not be shown.
Change the hatching's line width to a value other than 0.00 mm, perhaps 0.13mm, via Tools - Modify - Attributes.
rudi72
Thanks for your replay.
But I have 2 other questions:
1. why is always the screen jumping at autosave? This is very annoying !!
2. How can i make a box in a box only by commands.
for example: a box with 280X300. In this box i want a box at 194 in the hight, 17,5 from the left line , a box 145 long and 45 hight.
How can i do this by the commandline? To create the box is no problem, but it must be 17.5 from the left line.
Must i do this by two steps? First create then move?
1. Is a known issue, it's because of changing status bar height when the auto save message appear.
A fixed version is released soon.
2. See https://librecad.readthedocs.io/en/latest/guides/cmdline.html
Especially about using @ in the command line for relative coordinates.
And Calculator, what means, you can use formulas for coordinates.
e.g.:
rec
100,100
@280,300
100+17.5,194
@145,45
This creates a rectangle at 100,100, 280x300 and one at 117.5,194, 145x45
The rectangle command is still active after the second coordinate and the rectangle is created.
Watch the text above the command line and beside the mouse icon in the status bar, it always tell you what is expected next.
rudi72
OK!
Thanks!
