help
help
zohir
how to make a dimension for an arc
Re: help
Siprex3D
Hello Zohir
1) dimension button
2) radius dimension button
3) select the arc with the mouse crosshair
Re: help
zohir
hello  Siprex3D
thank you but I'm looking how to set the length of the arc
Re: help
sp1der
zohir wrote
hello  Siprex3D
Try:
Arc > Arc with Center, Point, Angles.
> Specify Center
> Specify Radius
> Specify Start Angle
> Specify End Angle or Angle/Chord Length
* Use the command line to enter inputs for any of the above, particularly the Chord Length.
Hope it helps ;)
