how do i subsequent dimensioning and scaling a Drawing from DXF-File
Gaudilover
i'm a newbie in CAD and LibreCAD.
Therefore my question is quite simple.
I want scale a dxf File of the attached picture to 50cm.
Unfortunately i cannot find any dimension or scale tools for an existing imported file.
After i imported the dxf, it is very small.
How could i bring the object to the dimension 50 cm height and width?
Regards
Jens
Gaudi Fliese
Re: how do i subsequent dimensioning and scaling a Drawing from DXF-File
Measure the imported picture with the info tool distance point to point from edge to edge.
Call up Tools - Modify - Scale:
At x insert 50/measured value, if the measured value is smaller than the wanted (50), or if bigger the other way around. Maths is a weak spot of mine.
