how to distribute objects evenly along an axis
2 messages Options Options
Burgi200
1 post
Dear gurus!
I have a line with eg 13cm length and want to distribute an object evenly eg 12 times along this line. The distance between the objects is a very ugly periodical number (divide 13 by 12). Now I could truncate/round this number and use the move/copy command to distribute the objects. I find this not very nice. Is there an other way to spread objects evenly in a specific range?
Thanks in advance for help!
Kurt
Re: how to distribute objects evenly along an axis
do you mean to move the object to the line center and rotated to the line direction?
1, select the object;
2, Modify->Move/Copy;
3, select the center of the object as reference point (snap to middle);
4, select the center of the line as target point to move to;
5, accept movement and "delete the old"
you can do similar Move/Copy to rotate the object to line direction as well.
Burgi200 wrote
Dear gurus!
Kurt
