how to get accurate angle dimensions
astrobits
I can't get LibreCAD to show accurate angles. The attached drawing has angle precision set for 3 decimal places but it is only showing whole degrees.
Nigel Wakefield
Re: how to get accurate angle dimensions
Check Angular zeros, untick remove right.
astrobits
Thanks for your reply dellus. Angular Zeros was set correctly but  I had the angles set for decimal in Units but not in Dimensions as well.
