LibreCAD - forum locked! please use https://discourse.librecad.org/ now
LibreCAD-user
Search
everywhere
only in this topic
Advanced Search
how to offset a geometry
Previous Topic
Next Topic
Classic
List
Threaded
Locked
9 messages
KRIS
Reply
Threaded
KRIS
Reply
Threaded
Re: how to offset a geometry
Reply
Threaded
modify -> offset
line->parallel
polyline-> create equidistant polylines
Reply
Threaded
In reply to
this post
by KRIS
commands: o, pa
http://wiki.librecad.org/index.php/Commands
It needs updating...
KRIS
Reply
Threaded
thank you , but the connection is not closed
Reply
Threaded
You can close the lines manually with modify - trim two.
Or you can make several objects into one with polylines - create polylines from existing segments and then apply create equidistant polylines.
KRIS
Reply
Threaded
okay but there is always an angle which is not closed.
for only okay, but I have to do 200 different forms on the same design
Reply
Threaded
Either close it with the 'tool options' toolbar, at the end of making the geometry,
or use modify -> properties (mp).
Reply
Threaded
Hm... it looks like changing the properties only creates a beveled corner (if you use it after offset).
Free forum by Nabble
Edit this page
