I need to gather several individual .dxf tiles (that are georeferenced) in one .dxf file. I would like to know if there is a faster way than copy / paste to 0,0 coordonates for each .dxf tile into the .dxf file. Does anyone get some hints? Thanks. Cheers |
It might be possible to import them as blocks (File->Import->Block), however that depends on:
1. Having common origins in all the files as the origin becomes the reference point for the inserted the drawing (similar to copy & paste). It is possible to work around that if you can adjust your placement when inserting. 2. All the layers of the inserted file will be added and that can create a problem (but, that might be a problem if you were to copy & paste too). It would be better to move everything in the drawing-to-be-inserted to layer 0. Each inserted drawing can be placed in its own layer in the consolidated drawing. |
Thanks Gary for the reply. I tried for 5 tiles and it worked
fine. I managed to copy and paster all layers to layer 0 but is there a quick way to delete several layers at the same time? Do I need to delete individually each layer?
Le 22/04/2021 à 23:35, Gary S [via
LibreCAD] a écrit :
It might be possible to import them as blocks (File->Import->Block), however that depends on: |
If you are using the LC 2.2.0 branch, yes. Multiple layers can be selected by using [Ctrl]-[Left Click] to select non-contiguous layers or [Shift]-[Left Click] to select contiguous layers, and then click the layer delete button. If you are using an older version, then no...
Another suggestion that may help you - Select all entities in a drawing with [Ctrl]-[A] and then use Tools->Modify->Attributes and change the Layer to "layer 0". It is a little simpler than using C&P... |
Thanks for the hints. I tried with [Ctrl] but with my LC is
2.1.3. So it failed. Modify entitites to layer 0 worked perfectly thanks :) Le 23/04/2021 à 16:46, Gary S [via
LibreCAD] a écrit :
If you are using the LC 2.2.0 branch, yes. Multiple layers can be selected by using [Ctrl]-[Left Click] to select non-contiguous layers or [Shift]-[Left Click] to select contiguous layers, and then click the layer delete button. If you are using an older version, then no... |
