lettering
lettering
SMITHY
im trying to add an outline around some lettering. the idea behind this is so once its plasma cut there will be a 6 mm gap between the letters and the peice they're cut from. im going to use this to stamp/ form the word into some thin aluminium sheet. scaling the letters didn't work. any suggestions?
Re: lettering
You may try Line - Parallel ( with distance set in Tool Options bar). But not handy if you have a lot of text...
Re: lettering
SMITHY
i can do it on fusion 360. puts like a boarder around the letter. problem then is exporting it to a dxf isn't working properly. and yes i did think of that but thats time consuming and i want to avoid that if possible
