libdxfrw / librecad DWG import bug
mr-miky
I did some testing with dwg2dxf and LibreCAD.
Both have the same problem, wrong rotation angle of the object imported. When I open the drawing objects that have different angle from 0 are positioned wrong. If I check the properties results the wrong angle. For objects rotated by 180 ° LibreCAD reports 3.14159 ° which is equivalent to Pi or 1 Rad. I checked and objects are rotated 90 ° I imported as 1.5708 ° -> Pi / 2.
Attached examples: test_acad.dxf saved in DXF from AutoCAD 2007 test.dwg the original saved from AutoCAD, test_librecad.
It seems that acad save in radians and libdxfrw0-0.6.1-1.1 treat them as degrees
https://www.dropbox.com/s/7x0o6j1kyahxujp/dwg.zip?dl=0
Re: libdxfrw / librecad DWG import bug
Hi Michele,
The bug is due to diferences saving angles in dwg & dxf.
Rotation angle in Insert entity are saved in radians in DWG and in degrees in DXF.
In your test.dwg file I have noticed another issue:
The block "kfl08" are not linked whit the insert entity.
I send two patches one for angles and another for link.
To verify compile yourself or wait for a new daily build (the patches are in both master and 2.0 branch)
Cheers,
