In LibreCAD-master/libraries/libdxfrw/src/libdxfrw.cpp
line 1770, there is: DBG("dxfRW::processHeader\n"); but line 23-28 says #ifdef DRW_DBG #include <iostream> //for debug #define DBG(a) std::cerr << a #else #define DBG(a) #endif searching for DRW_DBG resulted in no findings So is it possible to define DRW_DBG in: librecad/src/main/main.cpp line ca. 99 for (int i=0; i<argc; i++) { if (QString("--debug") == argv[i]) { RS_DEBUG->setLevel(RS_Debug::D_DEBUGGING); } } so we can get moooooooooooooooore debugging messgages Does that make sense? Or is it possible to define DRW_DBG when executing LCad? something like: librecad --debug 2 --define DRW_DBG >out.log ??? |
Is it a bad idea to change
for (int i=0; i<argc; i++) { if (QString("--debug") == argv[i]) { RS_DEBUG->setLevel(RS_Debug::D_DEBUGGING); } } to for (int i=0; i<argc; i++) { if (QString("--debug") == argv[i]) { RS_DEBUG->setLevel(RS_Debug::D_DEBUGGING); define DBG(a) std::cerr << a; //<--- this is the new line I wanted to be added } } ? |
I don't quite get what you want to achieve here. if you mean: #define DBG(a) std::cerr << a; //<--- this is the new line I wanted to be added parsing argv[] is carried out at running time, and parsing C style macros is carried out at cpp building time. Also, macros are not limited by scope, so the macros would be visible for lines thereafter, the if() and {} have no effect here. Thanks, dxli On Tue, Jul 16, 2013 at 11:55 AM, cantcode [via LibreCAD] <[hidden email]> wrote: Is it a bad idea to change -- Dongxu Li, Ph.D. www.librecad.org |
"I don't quite get what you want to achieve here."
I just wanted libdxfrw to print the debug messages if needed by the user of librecad. "... parsing C style macros is carried out at cpp building time...." Right, did not think of that. So my suggestion would not work for users which do not build librecad but just use it. I wanted a way for the user to also enable the debug messages of libdxfrw by passing --debug to librecad or something in those lines. |
it's exactly the idea of RS_Debug() class, use the debugging level control, make sure the level from argv[] is set properly, and RS_Debug() will ignore messages with lower levels. void RS_Debug::instance()->print(RS_Debug::D_DEBUGGING, const char* format ...) ; On Tue, Jul 16, 2013 at 3:08 PM, cantcode [via LibreCAD] <[hidden email]> wrote:
"it's exactly the idea of RS_Debug() class..."
I think the debug messages from libdxfrw (reading/writing dxf files) use DBG("dxfRW::processHeader\n"); for printing the messages. So libdxfrw does not use RS_Debug() (so it can be used in other projects I think). That's the reason I tried to find a simple way to make the DBG("") work. |
