print a window
print a window
Fredevans
Hello Chaps.
I would like to draw a window around a section of my drawing and then print just the contents of the window.
Is this possible?
thanks
many regards from South africa
Re: print a window
No, it is not possible this way.
What you can do, for instance, if you have a drawing made for A1 format, print a part of it on an A4 sheet.
In Print Preview you can shift around the sheet to the desired position.
But if you export to pdf there is this issue:https://forum.librecad.org/PDF-File-Size-management-tp5722455.html
The only other way I can think of is to draw a mask of nearly white filling (solid hatch, and white would appear black) with a rectangular opening.
Re: print a window
Fredevans
thanks Dellus-
this rather excludes librecad for my purpose because i need to be able to print ( or plot) parts of the assembly I am working on
Many thanks
 for your help
fred from south africa
