I try to define a cutting axe with an "A-A View" designed by 2 "A arrows"
To draw the A-A arrows I used "Measure - Aligned" and selected the same 2 points of the cutting axe as origine and end => Measure = 0, Edit it, replace "0" by A.
Result OK :
![](https://forum.librecad.org/file/n5722327/Image1.png)
I save, close and re-open the document, then :
(occurs also while continuing to draw - better reproductible by save/close/open)
![](https://forum.librecad.org/file/n5722327/Image2.png)
The arrow are not where defined/expected.
Trying to move them result in a time-out of LibreCad => Close
Questions
Am I doing something wrong ( Should I give a minimum thickness to my "measure" ( i.e. not null).
Is there a better way to achieve what I am trying to do? (draw two arrows with text = A)
Thanks
Best regards
JMJ
