A rectangle drawn by the "Rectangle" command is a polyline, one entity, and doesn't respond to a trim command. You have to "Explode" it first. Then you can use "Trim" or "Trim Two" and then delete the remaining line. There is no automatic removal of lines or line segments which lie upon the other.
