setting layers
setting layers
Birpal Kaur
I have to set different layers for the different views(i.e top, front and side) of an object in my plugin. so  can anyone tell me how to make use of these functions:-
  virtual void setLayer(QString name) = 0;
  virtual QString getCurrentLayer() = 0;
Re: setting layers
    /*! Set the current layer in current document, if not exist create it.
    *  \param name a QString with the name of the layer.
    /*! Get the current layer in current document.
    *  \return The name of the current layer.
Re: setting layers
Birpal Kaur
thanks Rallaz.
can you elaborate it more. Actually i dont know how to implement them.
Re: setting layers
Not much more to tell.
void layerDemo::execComm(Document_Interface *doc,
                             QWidget *parent, QString cmd)
//to make the compiler happy
    Q_UNUSED(cmd);
    Q_UNUSED(parent);
    QPointF start;
    QPointF end;
//stores current layer
    QString cl = doc->getCurrentLayer();
//create new layer called "bottom" and set current
    doc->setLayer( QString("bottom") );
//create a line in current layer ("bottom")
    start.setX = 0.0;
    start.setY = 0.0;
    end.setX = 10.0;
    end.setY = 0.0;
    doc->addLine(&start, &end);
//another layer, called "left"
    doc->setLayer( QString("left") );
//create a line in current layer ("left")
    end.setX = 0.0;
    end.setY = 10.0;
//restore as current the layer which had before running the plugin
    doc->setLayer( cl );
