specify horizontal unidirectional text
4 messages Options Options
Ramblin
1 post
Hi team,
How can I force all text in dimensions to be horizontal even when doing vertical or angled dimensions? ie use horizontal unidirectional dimensioning
At the moment I select the dimension and explode it. Then select just the text and rotate it to horizontal. Is there an option in the dimensioning preferences to force this automatically?
Also is it possible to dimension a small hole using a leader and horizontal text?
Thanks in advance.
Re: specify horizontal unidirectional text
I don't see this feature right now. Hopefully, we can still implement this in 2.0
In reply to this post by Ramblin
I start implementing this feature, you can test it in master branch.
But is incomplete, not work with radial & angular dims and the
text are not aligned horizontally
Working feature.
The text are correctly aligned and the dimension line splitted when needed.
Only remaining radial & angular dims
