testing 1.0.0rc2
abc
testing 1.0.0rc2
abc
Things I found out while testing librecad (may already be noted)
first thing I tried to do
http://imageshack.us/photo/my-images/829/75034745.png/
Featurerequest: would be nice if one could move an object along another object so I would just click on that button and could
move the circle along the line.
second ting I tried to do:
http://imageshack.us/photo/my-images/705/35101638.png/
BUG: #where it says "trim the lines" in the above picture I tried to cut the circle into two pieces but it does not work the way it should (worked in rc1) after cutting I can't select the circle and get "can't select the object" or sth. like that.
#can't save image cause librecad only shows "open" button but no "save" button. When hitting the camera button at the left
side.
Featurerequest: #make a "create an arc out of two points" so you would select two points and a half circle is drawn. Instead of drawing a circle through two points and cutting the upper part.
#trimming a line to a given length. So depending on the side of the line one is clicking the line gets the length one typed in.
Don not only beeing able to shorten or lenghten the line with the trimm tool but change the length of the line by typing in the length you want it to be.
#would also be nice if there would be a faster way to draw a line which is orthogonal to another line and is a tangent. So it would take me less than 7 steps to create a picture like the one above.
As I already mentioned I used the testing 1.0.0rc2 version and did not build from source so maybe some features/bugs are already known.
using win7 64bit
Re: testing 1.0.0rc2
ClaudeQC
Hello abc,
On 12/09/2011 6:25, abc [via LibreCAD] wrote:
 > Things I found out while testing librecad (may already be noted)
 > first thing I tried to do
 > http://imageshack.us/photo/my-images/829/75034745.png/
 > #would also be nice if there would be a faster way to draw a line which
 > is orthogonal to another line and is a tangent. So it would take me less
 > than 7 steps to create a picture like the one above.
 > As I already mentioned I used the testing 1.0.0rc2 version and did not
 > build from source so maybe some features/bugs are already known.
 > using win7 64bit
Please, could you put you bugs reports here:
Could you put you features requests here:
Claude
