windows installers
13 messages Options
windows installers
When I want to compile an installer for the latest commit,
is there a quick way to update only the changed files?
Or do I just clone the whole project again?
I would be willing to upload installers for Windows if that is agreeable.
What is the protocol for that?
Re: windows installers
using command line git tool, in your librecad source folder, run:
git fetch
git rebase
Thank you!
Am I allowed to post links to installers I have compiled and uploaded,
if I note that it is unofficial?
if you can be sure that it's virus free.
ravas wrote
Thank you!
Well I'm sure I didn't add any. ;-]
Do you trust http://www.filedropper.com/ ?
Regarding libxml++
has a package been prepared?
Where would I put it?
we actually have a windows building server available.
It's better to make the night building works:
redo building every day (or night);
if there's no new commit, stop here;
build an installer, upload it to sf.net
Regarding libxml++
Jim Winkler
Is it possible to get an up-to-date build? There are several fixes that I would find useful. I have installed LibreCAD-Installer-2.0.7-45-g00c66c0 which don't have them. Thanks -Jim
You can download a new Nightly Build Windows Installer:
LibreCAD-Installer-2.0.7-135-g90e2c72.exe in NightlyBuilds
This build is based on commit 90e2c72 from April 10th, including DWG support
I'm glad you mentioned dwg support!
I had just started manually converting all mine.
Jim Winkler
Thank you very much. The new features work. Much appreciated! -Jim
libxml++ dependency removed in master branch.
windows building should work as usual
I updated with git rebase, but it still complains about libxml++
is there a file that needs to be changed or removed?
Or do you recommend that I make a fresh clone?
The fix was:
git rebase origin/master
It built with no errors or warnings.
