z-order
z-order
Mike
I'm new to LibreCAD and I can't find out if there is a way of specifying the z-ordering of objects, i.e. which lines are drawn above others.
I have read the QCAD manual and it seems there is an option to "send to back" or "bring to front". Is there a way of doing this in LibreCAD?
Mike.
Re: z-order
Hi Mike,
this is an accepted feature request.
https://sourceforge.net/tracker/?func=detail&aid=3492292&group_id=342582&atid=1433847
Before this is implemented, the work around might be by layer order, as all layers are ordered by names.
Mike.
Re: z-order
Mike
Thanks for the quick response.
For me the drawing order seemed to be related to the order the lines were added to the drawing rather than which layer they were in.
I have a workaround now - if I cut a whole layer and immediately paste it back in again, all the lines in that layer are then drawn on top. I do that for each layer starting with the layer I want on the bottom and ending with the layer I want on top.
Mike.
Re: z-order
yes, the current implementation of entity container is by a QList, which is an ordered container.
The feature needed is to implement the GUI to allow user access to the internal order.
Mike.
