		Hi everyone,
				it would be so kind if you can give me a hint how i can chage the angel of a givven line, after i place it? Cheers  |
		hi olsch,
				Several ways: 1, click to select the line (it should be shown as dashed and changed color, after being selected); drag the reference points(i.e., start/end points) to modify the line. 2, Modify -> rotate, to rotate the line. 3, Modify-> properties to modify the coordinates.
	 On 02.09.2015 04:57, dxli [via
      LibreCAD] wrote:
    hi olsch,  |
    Hey dxli,
				thanks for the fast responde. Way one i a bit tricky sometimes with the left and right click. Way 2, if i select in the Modify menue the rotate botton and select a line to rotate, nothing happens. In the command line stands the apell to select something but nothing comes up. way 3 to modify the coordinates runs well, but the goal is to modefy to a modefy specific angels. thanks for tipps, but i dont get it now. I think also about, if libre cad the right program for my projekt cheers On 02.09.2015 04:57, dxli [via
      LibreCAD] wrote:
    hi olsch,  |
		Hi olsch,
				Please read an example of rotation at our wiki: http://wiki.librecad.org/index.php/LibreCAD_users_Manual#Further_tools
    Thats it what i searching for!
				Thanks for Help - topic closed! See you soon! On 02.09.2015 16:14, dxli [via
      LibreCAD] wrote:
    Hi olsch,  |
		I think we should add a message in mouse tip:
				"Select to Rotate" should read: "Select to Rotate; then press Enter" Currently, we have "pressing Enter", or "Clicking the Continue Button" to continue, but none is prompted to first time users. BTW, if you first select the line, then, do "Modify->Rotate", it will skip the selection stage, and less confusing.
		Dear dxli,
				it is very interesting that you mention also the idea of further development of the Manuels. Do I understand this in the right manner? In this way, I think that's very right to be considered dissolved question by beginners with the documentation. Do you care about the entry? I do not have an account for the Wiki yet. Cheers Oliver  |
		Please do create a wiki account, and help adding your tips to user wiki.
				BTW, currently, wiki is temporarily locked because it's in maintenance.
    sounds ironic :-)
				well lets see whats happens. i will take some fresh air, get into action ;~, cu On 02.09.2015 22:05, dxli [via
      LibreCAD] wrote:
    Please do create a wiki account, and help adding your tips to user wiki.  |
