Angel (SOLVED)
10 messages Options
Angel (SOLVED)
olsch
Hi everyone,
it would be so kind if you can give me a hint how i can chage the angel of a givven line, after i place it?
Cheers
Re: Angel
hi olsch,
Several ways:
1, click to select the line (it should be shown as dashed and changed color, after being selected); drag the reference points(i.e., start/end points) to modify the line.
2, Modify -> rotate, to rotate the line.
3, Modify-> properties to modify the coordinates.
olsch wrote
Hi everyone,
Cheers
Re: Angel
olsch
On 02.09.2015 04:57, dxli [via LibreCAD] wrote:
hi olsch,
Several ways:
olsch wrote
Hi everyone,
Cheers
http://forum.librecad.org/Angel-tp5712115p5712116.html
To unsubscribe from Angel, click here.
Re: Angel
olsch
Hey dxli,
thanks for the fast responde.
Way one i a bit tricky sometimes with the left and right click.
Way 2, if i select in the Modify menue the rotate botton and select a line to rotate, nothing happens. In the command line stands the apell to select something but nothing comes up.
way 3 to modify the coordinates runs well, but the goal is to modefy to a modefy specific angels.
thanks for tipps, but i dont get it now.
I think also about, if libre cad the right program for my projekt
cheers
hi olsch,
Several ways:
olsch wrote
Hi everyone,
Cheers
Re: Angel
Hi olsch,
Please read an example of rotation at our wiki:
http://wiki.librecad.org/index.php/LibreCAD_users_Manual#Further_tools
olsch wrote
Hey dxli,
cheers
> hi olsch,
> Several ways:
>     olsch wrote
>     Hi everyone,
>     Cheers
> discussion below:
> <http://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5712115&code=cG9zdEByZWdpb2xhYm9yLmRlfDU3MTIxMTV8MTAyNjY4NjkxNQ==>.
> NAML
> <http://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Re: Angel
olsch
Thats it what i searching for!
Thanks for Help - topic closed!
See you soon!
On 02.09.2015 16:14, dxli [via LibreCAD] wrote:
Hi olsch,
olsch wrote
Hey dxli,
cheers
> hi olsch,
> Several ways:
>     olsch wrote
>     Hi everyone,
>     Cheers
> discussion below:
> NAML
http://forum.librecad.org/Angel-tp5712115p5712120.html
Re: Angel
I think we should add a message in mouse tip:
"Select to Rotate" should read:
"Select to Rotate; then press Enter"
Currently, we have "pressing Enter", or "Clicking the Continue Button" to continue, but none is prompted to first time users.
BTW, if you first select the line, then, do "Modify->Rotate", it will skip the selection stage, and less confusing.
See you soon!
> Hi olsch,
>     olsch wrote
>     Hey dxli,
>     apell to
>     modefy to
>     cheers
>     > hi olsch,
>     > Several ways:
>     > 1, click to select the line (it should be shown as dashed and
>     changed
>     > color, after being selected); drag the reference points(i.e.,
>     > start/end points) to modify the line.
>     > 2, Modify -> rotate, to rotate the line.
>     > 3, Modify-> properties to modify the coordinates.
>     >     olsch wrote
>     >     Hi everyone,
>     >     it would be so kind if you can give me a hint how i can
>     chage the
>     >     angel of a givven line, after i place it?
>     >     Cheers
>     > If you reply to this email, your message will be added to the
>     > discussion below:
>     > http://forum.librecad.org/Angel-tp5712115p5712116.html
>     > To unsubscribe from Angel, click here
>     <http://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5712115&code=cG9zdEByZWdpb2xhYm9yLmRlfDU3MTIxMTV8MTAyNjY4NjkxNQ==%3E>.
>     > NAML
>     <http://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml%3E>
> discussion below:
> NAML
Re: Angel
olsch
Dear dxli,
it is very interesting that you mention also the idea of ​​further
development of the Manuels.
Do I understand this in the right manner?
In this way, I think that's very right to be considered dissolved
question by beginners with the documentation.
Do you care about the entry?
I do not have an account for the Wiki yet.
Cheers
Oliver
Re: Angel
Please do create a wiki account, and help adding your tips to user wiki.
BTW, currently, wiki is temporarily locked because it's in maintenance.
olsch wrote
Dear dxli,
Cheers
Oliver
Re: Angel
olsch
sounds ironic :-)
well lets see whats happens.
i will take some fresh air, get into action ;~,
cu
olsch wrote
Dear dxli,
Cheers
Oliver
http://forum.librecad.org/Angel-SOLVED-tp5712115p5712124.html
To unsubscribe from Angel (SOLVED), click here.
