Duplicate entities
Duplicate entities
LittleTinyWorkshop
Re: Duplicate entities
I don't think there is an easy way to do that.
To efficiently detect identical entities:
1, implement hash code for all entities;
2, implement an equal() member function for all, to be used to handle hash collisions;
sounds like an interesting small project.
LittleTinyWorkshop wrote
Hi
Is there a way in LibreCAD to select and erase any duplicate entities please.
Regards
LTW
Not really, because duplicated should mean exact copies generated by copying.
It's hard to define "similar" cleanly.
say, you have tolerance of 0.5 (ridiculously large to show the idea), and the 1D points are:
0 0.25 0.5 0.75 1. 1.25 1.5
so, 0.25 is a duplicate of 0, and 0.5 is a duplicate of 0.25.
it's hard to tell which ones to remove then.
R. van Twisk wrote
Sounds like a java solution :)
I guess would also consider entities that are near identical?
For example lines where start/end point's of each line are close to within a specific distance?
Ries
> Hi
> Regards
> LTW
> If you reply to this email, your message will be added to the discussion below:
> http://forum.librecad.org/Duplicate-entities-tp5712800p5712801.html <http://forum.librecad.org/Duplicate-entities-tp5712800p5712801.html>
> To start a new topic under LibreCAD-user, email [hidden email]
> To unsubscribe from LibreCAD, click here <http://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4499512&code=bGlicmVjYWRAcnZ0LmRkcy5ubHw0NDk5NTEyfDMxMzE2MjUxNQ==>.
> NAML <http://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
TinyLittleWorkshop
Hi
Thanks Dxli and Ries for your answers.
Somehow I managed to delete my first post by mistake .... anyway AutoCAD and QCAD and most other CAD programs have this option to select and delete duplicate entities, so it is something which is very normal to have in a CAD tool set!
It would be great if this could be added to LibreCAD  also.
TLW
