How to edit text?
How to edit text?
vlad1777d
How to edit text?
Here http://forum.librecad.org/Edit-text-td5709662.html was said, that here http://wiki.librecad.org/index.php/LibreCAD_version_2,_users_Manual/Guide_-_by_Bob_Woltz#Changing_Line_Properties is answer.
But there is information only about editing attributes. But changing text from attributes window is impossible.
Re: How to edit text?
Use the Modify menu and select Properties, you see the mouse pointer changing from an arrow to a cross.
When the pointer is a cross, left click on your text and the properties window appears where you can change text.
vlad1777d
Thank you very much ))
