only empty boxes/frames are shown for image/text? no line thickness?
11 messages Options Options
This post was updated on Jul 01, 2012; 11:30pm.
You need to disable "Draft" mode. Make sure you uncheck the following item:
Main menu: View->Draft
Re: only empty boxes/frames are shown for image/text? no line thickness?
sp1der
The Icon has changed since version 2.1
dcas2020
Thank you Lord of Bikes,
 ' draft ' mode was set and  causing my problem,
cleared it and OK now.
cheers,
Denis
follaiv@alice.it
Thanks a lot I solve the problem by click on the Draft Mode as you suggest
I the latest development version, "Draft" will be shown on in the corners of the drawing view. Hopefully, we will confuse users less.
PatrickNC
To dxli: I just read your message about new "Draft" messages, 4 months later.  I'm still reading posts about dimension problems while printing.  Always issues in software development between including it one simple way versus alternative options.  At least a "Draft" message of some sort get users onto a track to a solution. I'm not sure how well it will work but at least it's an effort to address the problem.
Christian
I do have the problem of text (dimensions or TEXT tool) only showing an empty rectangle while  draft mode is NOT ON.
At the moment I am stuck.
Well I am now unstuck: I just closed the program and re-opened it. It was just a local bug (the bugger!)
Matter closed for me
Micke77
Dziękuje bardzo.
Micke77
Dziękuję za pomoc, pozdrawiam.
In reply to this post by Christian
Please note, when the rendered text is determined to be too small (consider the extreme, if the whole text is only 1 pixel in height), only a bounding box is drawn, i.e. the behavior of Draft mode.
Christian wrote
