Fixed:
one serious bug: #460 several major bugs: #448, #451, #452, #458, dxfrw memory leak -------------------------git shortlog---------------------------------------------------------------------------- Armin Stebich (5): allow old CPP11 flag by custom.pro file for g++ 4.6 and older compiler fixed sf.net bug #452, trim two failed, when trim entity starts/ends on limiting entity fix path to makensis.exe in set-windows-env.bat fixed github issue #441, bad if expression in asciifile.cpp added SCMREVISION support for windows build Dongxu Li (13): drawing by order of layer names drawing by order of layer name and id switch from qSort to std::sort Avoid translating numeric, patch by Sergey Alyoshin bug#448: default export image by twice of screen resolution updated README to for MacPorts preserve dimension precision in drawing options bug#451 displayer sorted layer list added warning message for inscribed ellipse drawing bug#460, crash by invalid spline SCM version 2.0.3 bug#458, fixed symbols in dimension UI bug#458, fixed symbols in Text UI Pootle (3): Updated translations from pootle server Merge branch 'master' of https://github.com/LibreCAD/LibreCAD Updated translations after lupdate Rallaz (2): libdxfrw: fix mem_leak in drw_variant libdxfrw: fix mem_leak in drw_header |
Hi for all, What do you think about to put the credits of all the people at LibreCAD? It's just a suggestion! -- Bruno Gonçalves Pirajá Em Segunda-feira, 10 de Março de 2014 12:08, R. van Twisk [via LibreCAD]
<[hidden email]> escreveu:
Do you want me to test the 2.0.3 on macports and if it compiles/runs send a request to macports for a updated version? On Mar 10, 2014, at 10:05 AM, dxli [via LibreCAD] <[hidden email]> wrote: Fixed: If you reply to this email, your message will be added to the discussion below:
http://forum.librecad.org/preparation-for-2-0-3-release-tp5709669p5709670.html
To start a new topic under LibreCAD-dev, email [hidden email] To unsubscribe from LibreCAD-dev, click here. NAML |
Yes, we must give credits to all people working to make this free software project possible.
Can you help putting together a paragraph. Going through closed bugs would be helpful.
Yes, I can help to make the credits to put inside the LibreCAD. Em Segunda-feira, 10 de Março de 2014 22:01, dxli [via LibreCAD] <[hidden email]> escreveu:
http://forum.librecad.org/preparation-for-2-0-3-release-tp5709669p5709672.html
Where's the complete list of contributors of LibreCAD?(Complete list os names and nicknames). I think that for now this information helps a lot. And where's the complete list of fixed bugs? -- Bruno Gonçalves Pirajá Em , Bruno Gonçalves Pirajá <[hidden email]> escreveu:
people reporting bugs, provide troubleshooting information are very important as well.
Also, we want to give credits to people helping on docs, part library, etc. |
Hi everybody!
I didn't found the bug #32. I searched in this link: http://sourceforge.net/p/librecad/bugs/32/ Is this link correct? -- Bruno Gonçalves Pirajá |
