2.0.0alpha3 opinion after testing
7 messages Options
grypokx
Re: 2.0.0alpha3 opinion after testing
Hello grypokx,
Thanks for yours comments.
LibreCAD 2.0.0alpha3 is a old version the last is LibreCAD 2.0.0alpha4
or, if you want, you can test daily builds:
http://librecad.org/cms/home/installation/linux.html
For next version (v3) is planned to rewrite the entire core of the program. This is a good point to add the scripting feature
like lisp or python.
In v2 have support for c++ plugins, p.e. if in your version are present:
File->Import->assci points
File->Import->shape file
Modify->Align
Modify->Sameprop
Info->List
Then you have 5 "add-ons" in LibreCAD
About Draw>LINE, Draw>Arc
I suppose for the version 3 will be a good time to discuss it between developers and users
Cheers,
grypokx
Hi Rallaz
I've issued commands below in terminal but it does not update/upgrade my librecad version to 2.0.0alpha4.
I'm using ubuntu 12.04.
$ sudo add-apt-repository ppa:librecad-dev/librecad-daily
$ sudo apt-get update
$ sudo apt-get upgrade
The ad-ons are great, and i think should be kept (although i have not fully tested all).
I think there still a lot to comment on but help me update to latest build first.
cheers
maqifrnswa
On Mon, Aug 20, 2012 at 9:30 PM, grypokx [via LibreCAD]
<[hidden email]> wrote:
> Hi Rallaz
> tested all).
> first.
> cheers
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://forum.librecad.org/2-0-0alpha3-opinion-after-testing-tp5706972p5706977.html
> To start a new topic under LibreCAD-user, email
> [hidden email]
> To unsubscribe from LibreCAD-user, click here.
> NAML
Ha! I have every build turned on except precise... sorry about that,
turning precise on now.
maqifrnswa
In reply to this post by grypokx
Actually it is turned on, if you have 12.04 (precise) you should have
alpha4 already, see:
https://launchpad.net/~librecad-dev/+archive/librecad-daily/+packages
it's mislabelled, the file name says "quantal" but under the series
"Precise". I fixed the mislabel, but it should still be alpha4.
Cheers,
Scott
grypokx
Hi showard314
I've just tried the 3 commands above again. am still
Version: master
SCM Revision: 2.0.0alpha3
Compiled on: Aug 12 2012
The link you provided not working "page not found"
cheers
maqifrnswa
On Tue, Aug 21, 2012 at 10:09 AM, grypokx [via LibreCAD]
> Hi showard314
> Version: master
> cheers
You actually do have 2.0.0alpha4, it's incorrectly telling you it is
2.0.0alpha3.
dxli/ries - we have to bump:
SCMREVISION="2.0.0alpha3"
on line 13 of:
https://github.com/LibreCAD/LibreCAD/blob/master/librecad/src/src.pro
BTW, try this link:
Cheers,
Scott
