2-point line draws line with infinite extention
3 messages Options Options
ahaskins
I am new to libreCAD vsn 2.1.3 and still figuring it out but I think I have inadvertently set a mode or switch. In my drawing I have a couple of circles and drew a couple of vertical lines. When I went to draw a 2 point line across the vertical lines which I will use to trim the line, the 2-point line extends infinitely through the 2 points so I am unable to trim or divide it. I have tried removing the vertical lines and closing and re-opening the drawing. Next step would be to start over and not use the vertical lines and see if that works. Any suggestions would be  appreciated.
Alan
Re: 2-point line draws line with infinite extention
Simple. Untick Construction Layer in Layer List. Hard to see, grey versus green.
ahaskins
Much thanks
