Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
we are adding the eigen library to v3, and I think it's a good idea to add it to v2 as well.
The eigen library is header only (as boost), but still need a little work to set up dependency for all platforms. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
If it will solve https://github.com/LibreCAD/LibreCAD/issues/523
then I support it. ;-] Otherwise I suggest waiting until 2.2.0. It would be helpful to minimize changes until the release of 2.1.0 because I'm almost ready to tag it as beta. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Yes, the current PoC version seems to be good with issue 523:
Lots of cleanup needed though. You may test from my branch: https://github.com/dxli/LibreCAD/tree/quadratic
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
All I did was:
brew install eigen and it built. This problem remains: 1. using Polygon (Cor,Cor) create a triangle with points (0,0) and (10,0) 2. using Tangential 3 Circles create the incircle of the triangle 3. using the 2 Points line tool try to create the contact triangle using Snap Intersection It does not snap to the tangent point that would be at (5,0). |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I switched it from inches to millimeters and it finds the (5,0) intersection.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Disregard that... millimeters didn't change anything... I think I had snap middle on.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Repeating the test, but with base points (100,100) & (110,100)
it will find the base intersection of (105,100) but not the other two. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
There are actually two problems:
1, found two closely spaced intersections for one; 2, found none. For issue (1), it was quite bad, showing errors from equation solvers at the 10^-8 level. The solvers are now with better precision level, so I don't see the issue (1) any more. The quartic solver is not touched yet, but work has been done for (quadratic, cubic, and quadratic-quadratic). For issue (2), I think it might be managed partly by investigating tolerance levels. If roots are found by precision of 10^-10, and testing intersections at the same level seems to be tough. This comes back to the old idea, we should consider the drawing precision level, for example, if user precision is 10^-5, we may consider intersections at 10^-7. There's no clear solution yet, unfortunately.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Forgot to mention, it's needed to build with LC_DEBUGGING to use the new solvers:
qmake -r librecad.pro DEFINES += LC_DEBUGGING |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
hi ravas,
it seems to be better for me now. Can you update and test again?
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
It looks like you solved the problem of the missing tangent point (yay!).
The double intersection problem doesn't seem to appear until there is more than 7 digits. I'm not sure if this is an improvement on what we had before. I tried testing with 2.0.10, but the missing tangent point problem exists there. I guess you added a couple of commits to 2.0. It might be preferable to revert those, for an easier frame of reference. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Is it possible to add the patch for the missing tangent point, without adding eigen?
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
No.
I feel I should merge my quadratic branch (with eigen). The equations solvers should offer better precision by: some "long double" intermediate, Kahan summation. RS_Math is a namespace now, instead of an all static class. I will remove the Vasilis' coincs code for the time being, because my initial attempt to convert the interface to LC style failed, and Vasilis will be able do the integration of his toolset better. The trouble would be building scripts: 1, Linux, needs eigen3 through pkg-config; 2, Mac: need to test whether pkg-config + eigen3 also works; 3, Windows, need to update wiki to manually download and configure similar to boost, since eigen is header only as well. I currently don't have access to windows or mac. Can you help me out here?
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I switched from Windows to openSUSE.
I think Qt's macdeployqt is enough for OS X. Since adding eigen to 2.1.0 is going to make the release more difficult, it might be prudent to make a 2.1 branch soon and then add eigen to the master (2.2). I'm mostly ready to tag 2.1.0 as beta. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
no problem. My quadratic branch is based on the master branch, meaning it's trivial to use "git merge --squash" or "git rebase " on the master branch.
