Today I installed LibreCAD under Linux Mint Debian Edition (latest release). I have the same problem reported by others i.e. the Help panes remainig empty when I choose Help|Manual. I was wondering, are the LibreCAD help files available somewhere for download? Alternatively: Is it possible to get by using QCad documentation? Otherwise the software appears very good. Thank you. |
Thanks for the information Ries,
As I said I'm running the latest release of Linux Mint Debian Edition (which is a rolling release based on Debian testing - whatever that means). Perhaps as a raw beginner at Linux (I only installed LMDE a few days ago) I'd do better to install something a bit more stable. I don't want to base my choice of distro on one piece of software but I would like to do CAD so, as a matter of interest, under which Linux will the LibreCAD Help|Manual function work? Dick Summerfield, Eindhoven. At 22:38 20/09/2011, you wrote: >You can always use teh QCAD documentation as found here : <http://www.qcad.org/qcad/manual_reference/>http://www.qcad.org/qcad/manual_reference/ > >Please remember that QCAD evolved to version 3 and not everything that is available in QCAD is >in LibreCAD. > >The reason why the doc doesn't appear in Debian is properly because you are using a rc1 or lower >release. > >Ries > >On Sep 20, 2011, at 3:35 PM, Battus [via LibreCAD] wrote: > >>Hi, >>Today I installed LibreCAD under Linux Mint Debian Edition (latest release). >>I have the same problem reported by others i.e. the Help panes remainig empty when I choose Help|Manual. >>I was wondering, are the LibreCAD help files available somewhere for download? >>Alternatively: Is it possible to get by using QCad documentation? >> >>Otherwise the software appears very good. Thank you. >> >> >> >> >> >>If you reply to this email, your message will be added to the discussion below: >><http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823956.html>http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823956.html >>To start a new topic under LibreCAD, email [hidden email] >>To unsubscribe from LibreCAD, click here. > > >If you reply to this email, your message will be added to the discussion below: ><http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823983.html>http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823983.html >To unsubscribe from Another new user, < here. |
Hi - first make sure you installed librecad-doc package, it should be
automatically installed but is listed as a "recommends" which on some systems isn't installed. If it is installed, you can grab the librecad package from Debian unstable. Download librecad (for your architecture), librecad-data, and librecad-doc from: http://ftp.debian.org/debian/pool/main/libr/librecad/ to an empty directory, then run the command: $ sudo dpkg -i *.deb in that directory. There is also a preview version for Ubuntu (which may also work for LMDE.) Instructions are available: http://librecad.org/cms/home/installation/linux.html LMDE is as good of a distribution as any for librecad, and if you have the package from debian testing then it has been shown to already work. Can you run: $ dpkg -s librecad | grep Version and let me know what the output is? On Wed, Sep 21, 2011 at 8:12 AM, Battus [via LibreCAD] <[hidden email]> wrote: > Thanks for the information Ries, > > As I said I'm running the latest release of Linux Mint Debian Edition (which > is a rolling release based on Debian testing - whatever that means). > Perhaps as a raw beginner at Linux (I only installed LMDE a few days ago) > I'd do better to install something a bit more stable. > I don't want to base my choice of distro on one piece of software but I > would like to do CAD so, as a matter of interest, under which Linux will the > LibreCAD Help|Manual function work? > > Dick Summerfield, > Eindhoven. > > At 22:38 20/09/2011, you wrote: > >>You can always use teh QCAD documentation as found here : >> <http://www.qcad.org/qcad/manual_reference/>http://www.qcad.org/qcad/manual_reference/ >> >>Please remember that QCAD evolved to version 3 and not everything that is >> available in QCAD is >>in LibreCAD. >> >>The reason why the doc doesn't appear in Debian is properly because you are >> using a rc1 or lower >>release. >> >>Ries >> >>On Sep 20, 2011, at 3:35 PM, Battus [via LibreCAD] wrote: >> >>>Hi, >>>Today I installed LibreCAD under Linux Mint Debian Edition (latest >>> release). >>>I have the same problem reported by others i.e. the Help panes remainig >>> empty when I choose Help|Manual. >>>I was wondering, are the LibreCAD help files available somewhere for >>> download? >>>Alternatively: Is it possible to get by using QCad documentation? >>> >>>Otherwise the software appears very good. Thank you. >>> >>> >>> >>> >>> >>>If you reply to this email, your message will be added to the discussion >>> below: >>><http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823956.html>http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823956.html >>>To start a new topic under LibreCAD, email [hidden email] >>>To unsubscribe from LibreCAD, click here. >> >> >>If you reply to this email, your message will be added to the discussion >> below: >><http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823983.html>http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823983.html >>To unsubscribe from Another new user, < here. > > > ________________________________ > If you reply to this email, your message will be added to the discussion > below: > http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4826120.html > To start a new topic under LibreCAD-user, email > [hidden email] > To unsubscribe from LibreCAD-user, click here. |
On 21/09/2011 10:17, showard314 [via LibreCAD] wrote: > > Hi - first make sure you installed librecad-doc package, it should > be > automatically installed but is listed as a "recommends" which on > some > systems isn't installed. > > If it is installed, you can grab the librecad package from Debian > unstable. > > Download librecad (for your architecture), librecad-data, and > librecad-doc from: > http://ftp.debian.org/debian/pool/main/libr/librecad/ > > to an empty directory, then run the command: > > $ sudo dpkg -i *.deb > > in that directory. > - This will not work, since the package you refer to is LibreCAD 1.0.0 RC1, and RC1 have not a functionnal manual. Claude |
On Wed, Sep 21, 2011 at 11:05 AM, ClaudeQC [via LibreCAD]
<[hidden email]> wrote: > > On 21/09/2011 10:17, showard314 [via LibreCAD] wrote: > > > > > Hi - first make sure you installed librecad-doc package, it should > > be > > automatically installed but is listed as a "recommends" which on > > some > > systems isn't installed. > > > > If it is installed, you can grab the librecad package from Debian > > unstable. > > > > Download librecad (for your architecture), librecad-data, and > > librecad-doc from: > > http://ftp.debian.org/debian/pool/main/libr/librecad/ > > > > to an empty directory, then run the command: > > > > $ sudo dpkg -i *.deb > > > > in that directory. > > > > - This will not work, since the package you refer to is > LibreCAD 1.0.0 RC1, and RC1 have not a functionnal > manual. > > > Claude I believe Lisandro and I patched the code to get the help working: http://packages.debian.org/changelogs/pool/main/libr/librecad/librecad_1.0.0~rc1+nolibs-4/changelog but I could be wrong (too many betas and RCs dancing in my head!) ~Scott |
On 21/09/2011 13:27, showard314 [via LibreCAD] wrote: > > On Wed, Sep 21, 2011 at 11:05 AM, ClaudeQC [via LibreCAD] > <[hidden email] </user/SendEmail.jtp?type=node&node=4827175&i=0>> wrote: > > > > > On 21/09/2011 10:17, showard314 [via LibreCAD] wrote: > > > > > > > > Hi - first make sure you installed librecad-doc package, it should > > > be > > > automatically installed but is listed as a "recommends" which on > > > some > > > systems isn't installed. > > > > > > If it is installed, you can grab the librecad package from Debian > > > unstable. > > > > > > Download librecad (for your architecture), librecad-data, and > > > librecad-doc from: > > > http://ftp.debian.org/debian/pool/main/libr/librecad/ > > > > > > to an empty directory, then run the command: > > > > > > $ sudo dpkg -i *.deb > > > > > > in that directory. > > > > > > > - This will not work, since the package you refer to is > > LibreCAD 1.0.0 RC1, and RC1 have not a functionnal > > manual. > > > > > > Claude > > > I believe Lisandro and I patched the code to get the help working: > http://packages.debian.org/changelogs/pool/main/libr/librecad/librecad_1.0.0~rc1+nolibs-4/changelog > > but I could be wrong (too many betas and RCs dancing in my head!) > - Sorry Scott, I was not aware that this LibreCAD V1.0.0 RC1 was patched to fix the help->manual bug. - So, forget my previous post. Claude |
tcc@tcc:~$ On Ubuntu 12.10, LibreCAD Version: 1.0.2 SCM Revision: 1.0.2 Compiled on: May 17 2012, also has no manual. Repositories showed three packages, when searched for LinreCAD, two were installed, third was qcad, which I installed. sudo apt-get install qcad Get:1 http://us.archive.ubuntu.com/ubuntu/ quantal/universe qcad all 2.0.5.0-1+090318.1-2 [3,550 B] But manual is still not there.
H.S.Rai |
