Little problems
6 messages Options Options
Little problems
gnat012
I'm working with LC compiled on mar 7 2013 and Windows 7 and XP.
1) When I use "Menu > Modify > Same properties"  LC always crashes.
2) Layers: when I toggle off the icon "No print", the layer is not visible in the Print Preview but is still be printed.
3)"Menu > Info > Poligonal Area": is it possible to measure the area of a circle or ellipse?
Thank you for the good support you always give.
Re: Little problems
1. "Same properties" is a plugin, verify if you have only one time sameprop.dll file
   another option is update LC installation, a new beta version is going to publish very soon
2. "No print": I tested this with latest code and still be printed, this seems a bug
workaround: hide the layer is not to be printed.
please open a bug report in:
http://sourceforge.net/tracker/?func=browse&group_id=342582&atid=1433844
Another print related bug: select a entity, then select "print preview" entity are shown selected,
select "print" the selected entity are not printed.
3. "Poligonal Area" can't calculate area of circle or ellipse, only a closed polygon indicated by clicking points
Options: Calculate it yourself (A = pi * minor axis * major axis)
You can view data with "modify->properties"
open a feature request in:
http://sourceforge.net/tracker/?atid=1433847&group_id=342582
Re: Little problems
About "Same properties" may be a "bug" packaging LC for windows (mar 7 2013),
update to latest build from this thread:
precompiled LC for windows 2013-04-17
Re: Little problems
gnat012
About "Same properties", I updated to the latest build 2013-04-16. The problem is still the same.
Re: Little problems
before upload I tested the plugin in a win XP and no crash :-(
when crash occurs ?
    directly by selecting it from the menu
    on select original entity
    or selecting entities to change
   or canceling the command
if you move the file "librecad2.0.0beta1-git2013-04-16\resources\plugins\sameprop1.dll" to other location (rename not serves) and reopen LC "Modify > Same properties"is still present ?
Re: Little problems
gnat012
In reply to this post by gnat012
Correction of the message above: the problem with "Same properties" is solved. It is the problem with printing (2) that is the same.
