Another new user
8 messages Options
Another new user
Scribbler
Today I installed LibreCAD under Linux Mint Debian Edition (latest release).
I have the same problem reported by others i.e. the Help panes remainig empty when I choose Help|Manual.
I was wondering, are the LibreCAD help files available somewhere for download?
Alternatively: Is it possible to get by using QCad documentation?
Otherwise the software appears very good. Thank you.
Re: Another new user
Scribbler
Thanks for the information Ries,
As I said I'm running the latest release of Linux Mint Debian Edition (which is a rolling release based on Debian testing - whatever that means).
Perhaps as a raw  beginner at Linux (I only installed LMDE a few days ago) I'd do better to install something a bit more stable.
I don't want to base my choice of distro on one piece of software but I would like to do CAD so, as a matter of interest, under which Linux will the LibreCAD Help|Manual function work?
Dick Summerfield,
Eindhoven.
At 22:38 20/09/2011, you wrote:
>You can always use teh QCAD documentation as found here : <http://www.qcad.org/qcad/manual_reference/>http://www.qcad.org/qcad/manual_reference/
>Please remember that QCAD evolved to version 3 and not everything that is available in QCAD is
>in LibreCAD.
>The reason why the doc doesn't appear in Debian is properly because you are using a rc1 or lower
>release.
>Ries
>On Sep 20, 2011, at 3:35 PM, Battus [via LibreCAD] wrote:
>>Hi,
>>If you reply to this email, your message will be added to the discussion below:
>><http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823956.html>http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823956.html
>>To start a new topic under LibreCAD, email [hidden email]
>>To unsubscribe from LibreCAD, click here.
><http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823983.html>http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4823983.html
>To unsubscribe from Another new user, < here.
maqifrnswa
Hi - first make sure you installed librecad-doc package, it should be
automatically installed but is listed as a "recommends" which on some
systems isn't installed.
If it is installed, you can grab the librecad package from Debian unstable.
Download librecad (for your architecture), librecad-data, and librecad-doc from:
http://ftp.debian.org/debian/pool/main/libr/librecad/
to an empty directory, then run the command:
$ sudo dpkg -i *.deb
in that directory.
There is also a preview version for Ubuntu (which may also work for
LMDE.) Instructions are available:
http://librecad.org/cms/home/installation/linux.html
LMDE is as good of a distribution as any for librecad, and if you have
the package from debian testing then it has been shown to already
work. Can you run:
$ dpkg -s librecad | grep Version
and let me know what the output is?
On Wed, Sep 21, 2011 at 8:12 AM, Battus [via LibreCAD]
> Dick Summerfield,
> Eindhoven.
>>in LibreCAD.
>>release.
>>Ries
>>>Hi,
>>> release).
>>> download?
>>> below:
>> below:
> ________________________________
> below:
> http://librecad.1049103.n5.nabble.com/Another-new-user-tp4823956p4826120.html
> To start a new topic under LibreCAD-user, email
> [hidden email]
> To unsubscribe from LibreCAD-user, click here.
ClaudeQC
On 21/09/2011 10:17, showard314 [via LibreCAD] wrote:
 > Hi - first make sure you installed librecad-doc package, it should
 > be
 > automatically installed but is listed as a "recommends" which on
 > some
 > systems isn't installed.
 > If it is installed, you can grab the librecad package from Debian
 > unstable.
 > Download librecad (for your architecture), librecad-data, and
 > librecad-doc from:
 > http://ftp.debian.org/debian/pool/main/libr/librecad/
 > to an empty directory, then run the command:
 > $ sudo dpkg -i *.deb
 > in that directory.
- This will not work, since the package you refer to is
   LibreCAD 1.0.0 RC1, and RC1 have not a functionnal
   manual.
Claude
maqifrnswa
On Wed, Sep 21, 2011 at 11:05 AM, ClaudeQC [via LibreCAD]
>  > be
>  > some
>  > unstable.
>    manual.
> Claude
I believe Lisandro and I patched the code to get the help working:
http://packages.debian.org/changelogs/pool/main/libr/librecad/librecad_1.0.0~rc1+nolibs-4/changelog
but I could be wrong (too many betas and RCs dancing in my head!)
~Scott
ClaudeQC
On 21/09/2011 13:27, showard314 [via LibreCAD] wrote:
 > On Wed, Sep 21, 2011 at 11:05 AM, ClaudeQC [via LibreCAD]
 > <[hidden email] </user/SendEmail.jtp?type=node&node=4827175&i=0>> wrote:
 >  > On 21/09/2011 10:17, showard314 [via LibreCAD] wrote:
 >  > > Hi - first make sure you installed librecad-doc package, it should
 >  > > be
 >  > > automatically installed but is listed as a "recommends" which on
 >  > > some
 >  > > systems isn't installed.
 >  > > If it is installed, you can grab the librecad package from Debian
 >  > > unstable.
 >  > > Download librecad (for your architecture), librecad-data, and
 >  > > librecad-doc from:
 >  > > http://ftp.debian.org/debian/pool/main/libr/librecad/
 >  > > to an empty directory, then run the command:
 >  > > $ sudo dpkg -i *.deb
 >  > > in that directory.
 >  > - This will not work, since the package you refer to is
 >  >    LibreCAD 1.0.0 RC1, and RC1 have not a functionnal
 >  >    manual.
 >  > Claude
 > I believe Lisandro and I patched the code to get the help working:
 > but I could be wrong (too many betas and RCs dancing in my head!)
- Sorry Scott, I was not aware that this LibreCAD V1.0.0 RC1 was
   patched to fix the help->manual bug.
- So, forget my previous post.
Claude
Mauanl [was] Re: Another new user
hsrai
tcc@tcc:~$
On Ubuntu 12.10, LibreCAD Version: 1.0.2 SCM Revision: 1.0.2 Compiled on: May 17 2012, also has no manual.
Repositories showed three packages, when searched for LinreCAD, two were installed, third was qcad, which I installed.
sudo apt-get install qcad
Get:1 http://us.archive.ubuntu.com/ubuntu/ quantal/universe qcad all 2.0.5.0-1+090318.1-2 [3,550 B]
But manual is still not there.
H.S.Rai
