Are there suggested limited dimensions for LC files?
claus82
Hi everyone.
I've considered my activities and I compared mechanical works with my drawings, then I noticed that my drawings are mostly heavier (2 - 3 - 5 Megs, how about your works?), so I simply asked myself if there is a suggested limit for the files dimension of LC (e.g. 6 Megs), in order to avoid crashes, troubles ecc...
Then I'm putting here my question.
Waiting for your answers!
See ya!
Claus
Re: Are there suggested limited dimensions for LC files?
sp1der
Hello my friend,
Claus, I think architectural drawings will at most times be heavier files than mechanical drawings.
Most of my drawings are either mechanical type drawings or drawings for laser cutting and are not too heavy !
What would you suggest is a good limit for drawing size for LibreCAD?
@Developers what do you think about this too?
claus82
Well, then I consider 4 - 5 megs maximum!
See ya!
It is (finally) a nice day, so I'm going to have a ride with my bicycle, or maybe I'll go out with my dogs!
