Hi everyone,
I know it's a lot to ask, but does anyone know a way to use the PDF export command of LibreCAD remotely without needing a user to operate the CAD manually? I am working with Python and ezdxf to produce simple DXF files (GA drawings) automatically, and I am using LibreCAD to generate the templates and block libraries. It is working great so far, but I would like to explore a way to generate the PDF automatically as well. Any suggestion is very welcome! Thanks
Have a look at dxf2pdf
https://github.com/LibreCAD/LibreCAD?tab=readme-ov-file#dxf-converter
Thanks I could not get proper output quality with dxf2pdf but I found a nice way to do it with pyautogui See here: import time import os import pyautogui def open_data(app_instance): try: # Open the Excel file with the default application os.startfile(app_instance.jobfilexls) except Exception as e: print(f"An error occurred: {e}") # def on_button_hover(app_instance, event): # app_instance.write_button["background"] = "#A9A9A9" # # def on_button_leave(app_instance, event): # app_instance.write_button["background"] = "#D3D3D3" def open_cad(app_instance): print('ok') try: # Open the Excel file with the default application os.startfile(app_instance.jobfiledxf) except Exception as e: print(f"An error occurred: {e}") def print_pdf(app_instance): # Get the folder and filename without extension folder_path = os.path.dirname(app_instance.jobfiledxf) file_name = os.path.basename(app_instance.jobfiledxf).replace('.dxf', '') # Define the path for the PDF pdf_path = os.path.join(folder_path, f"{file_name}.pdf") # Open LibreCAD print("Opening LibreCAD...") os.startfile("C:\\Program Files (x86)\\LibreCAD\\LibreCAD.exe") time.sleep(5) # Wait for LibreCAD to open # Handle input device dialog print("Handling input device dialog...") time.sleep(2) # Give some time for the dialog to appear pyautogui.press('enter') time.sleep(2) # Wait for the dialog to close # Open the DXF file print("Opening DXF file...") pyautogui.hotkey('ctrl', 'o') time.sleep(2) pyautogui.typewrite(app_instance.jobfiledxf) pyautogui.press('enter') time.sleep(5) # Wait for the file to open # Navigate to Print Preview print("Navigating to Print Preview...") pyautogui.hotkey('alt', 'f') # Open file menu time.sleep(1) pyautogui.press('down', presses=9, interval=0.2) # Navigate to 'Print Preview' pyautogui.press('enter') time.sleep(2) # Export as PDF print("Navigating to Export as PDF...") pyautogui.hotkey('alt', 'f') # Open file menu time.sleep(1) pyautogui.press('down', presses=7, interval=0.2) # Navigate to 'Export' pyautogui.press('right') time.sleep(1) pyautogui.press('down', presses=1, interval=0.2) # Navigate to 'Export as PDF' pyautogui.press('enter') time.sleep(2) # Save PDF and handle overwrite prompt print(f"Saving PDF as {pdf_path}...") pyautogui.typewrite(pdf_path) pyautogui.press('enter') time.sleep(2) # Wait for the "Save As" dialog to respond # Handle the overwrite prompt if it appears # Most dialogs will accept 'Enter' to overwrite, but this depends on LibreCAD's behavior pyautogui.press('enter') time.sleep(2) # Wait for the save operation to complete # Navigate to Quit print("Navigating to Quit...") pyautogui.hotkey('alt', 'f') # Open file menu time.sleep(1) pyautogui.press('down', presses=12, interval=0.2) # Navigate to 'Print Preview' pyautogui.press('enter') pyautogui.press('right') time.sleep(1) pyautogui.press('enter') time.sleep(2) print("LibreCAD closed.") |
That's great. How about putting a few files together to use as a tutorial to replace https://dokuwiki.librecad.org/doku.php/usage:tutorials#advanced? I'd be happy to tidy it up and load it. btw, Are those block libraries publicly available? |
libraries are publicly available and free, especially ezdxf is really great for drawing automation. I could help for a tutorial but I would like to wait for September when I will get the feedback from some users that are doing the beta testing. It is working well till now. |
