BUG: Values rounded
BUG: Values rounded
Lisandro Damián Nicanor Pérez Meyer
Original bug submitter: "Jean-Luc Coulon \(f5ibh\)" <jean.luc.coulon@gmail.com>
Bug URL: <http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=640390>
--8<----8<----8<----8<----8<----8<----8<----8<----8<----8<----8<----8<--
I've several dxf files created with qcad.
I've switched to librecad and I remarked that several values are rounded.
i.e, a radius value is 4.5 in qcad and displayes (both on the drawing and in the
properties) as 4
If I edit it in librecad to change the value, it is correct while in the session
but if I close and reopen the drawing, I've the same behaviour.
The properties are the sam in both the softwares e:  'length fixed to 0.0000'
Attached:
- - a capture of the same design in both qcad and librecad
- - both the config files from qcad and librecad
Regards
Jean-Luc
The attachments can be found at the Debian's bug URL above.
Regards, Lisandro.
Re: BUG: Values rounded
Lisandro D. N. Pérez Meyer
I was pinted out to the bug tracker on IRC. I couldn't find a link on it on
LibreCAD's web page. Have I missed it?
Regards, Lisandro.
<RodoB> Tal vez le ponga un debian para manterlo actualizado mas facil.
<angasule> depende el uso que le des, para lo que usan mis viejos, no
           le veo sentido cambiarlos
<RodoB> Lo que mas cambia es el msn. Yo con el gaim viejo que tengo no
        puedo ver las fotos de los que usan el msn messenger. Algo
        cambio. Con el pidgin que tengo en mi casa todo bien.
<angasule> ah, si, eso si, pero mis viejos no usan MSN, imaginate que
           mi viejo una vez uso IRC y cuando terminaba de escribir
           ponia "cambio"
http://perezmeyer.com.ar/
http://perezmeyer.blogspot.com/
signature.asc (853 bytes) Download Attachment
In reply to this post by Lisandro Damián Nicanor Pérez Meyer
El día 4 de septiembre de 2011 22:21, Lisandro Damián Nicanor Pérez
Meyer [via LibreCAD] <[hidden email]>
> <[hidden email]>
> Hi,
> the
> properties) as 4
> session
> 0.0000'
> Attached:
> Regards
> Jean-Luc
See the comment in:
https://sourceforge.net/tracker/?func=detail&aid=3404105&group_id=342582&atid=1433844
