Block Editing by new user
7 messages Options
KD4LOK
I wish to change the length of a block.  Example: Piece of lumber 1x4x80.  I wish to make a new block 1x4x40.  Is there a simple way to do this?  Thanks.  Bob
Re: Block Editing by new user
I don't have much experience with blocks, but try with this:
And see here: https://librecad.readthedocs.io/en/latest/guides/blocks.html#editing-a-block
Maybe you have to save it to a file and then insert with the library browser.
Or do we need an extra option to save the edited block as a new additional block?
In reply to this post by KD4LOK
Or insert the existing block somewhere on the screen, explode it, edit it, and then create new block of it.
My first reading was that you mean a block of wood you have drawn with simple line entities.
Then I would make a parallel line from on side with distance 40 and trim the two long lines there.
If the block is a rectangle you have to explode it first.
When block means a library block, then simply use the Modify -> Properties tool.
Set the X or Y scale to 0.5 and you are done.
Oh, if your issue is what LordofBikes is talking about, I can also recommend the Stretch tool. Watch what commandline asks for.
KD4LOK
Thanks for the replies.  Yes, I did mean a library Block created as a 1 by 4, 80 inches long.  I thought I might be missing a way to change the length of the Block without Exploding it and then editing as lines.  I also tried the Modify >Properties approach but when I set X scale to .5, Y became blanked out and I was unable to leave Y at 1 so both X and Y were scaled to half size.
KD4LOK
Sorry.  I mis-spoke above when I commented on trying  Modify > Properties.  I was trying Modify > Attributes and with ISO checked when I could not independently control the X and Y inputs.  I will try the Modify > Properties as suggested.  Thanks.
