Block Library
7 messages Options Options
Block Library
Gary S
There are many resources for CAD blocks available on the 'net.  I was able to find a few "dxf" files scattered about, but more often than not what I found were "dwg" files that could not be used with LibreCAD.  I started drawing a few of my own and ended up going down that rabbit hole.  The result was a reasonable collection that others might find useful so I created a GitHub repository specifically for dxf CAD blocks and posted what I have: dxfBlocks.
To download the collection, follow the link above, click the Clone or Download button and then "Download ZIP" to get the entire library.  Refer to the LibreCAD User Manual - Blocks for details on using installing and using blocks.
 I hope you find them useful.
Re: Block Library
Excellent. All imperial units?
Re: Block Library
redcarrot
Hi
New to Github. How do I download these.
Cannot find the download/clone in your link.
Regards
Re: Block Library
Gary S
Click on the "Code" button and then "Download ZIP":
Re: Block Library
redcarrot
Thanks Mate! Have a good one!
Re: Block Library
Jack
1 post
New to LibreCAD, made a floor plan. Downloaded Gary S Block Library.  Located it in my Windows Explorer, un-zipped it into my 'users' directory.  In LibreCAD, opened Application Preferences to Defaults, placed address into Part Libraries, went to Widgets/Dock Widgets/Library Browser.  But nothing from his Library shows up.  Can someone advise me what I may have done wrong please?
Re: Block Library
When you select the library path. Select the folder contains subfolders, which contains the actual dxf files.
Or, you can copy the dxf file containing folder to c:\program files\librecad\resources\library, and restart
