[Bug] rs_actiondrawellipsecenter3point
15 messages Options Options
cantcode
Hey guys cause I would like to learn how to code, I was trying to find the cause of a bug.
When drawing an ellipse from the center and three points (rs_actiondrawellipsecenter3points)
there seems to be a bug.
Trying to figure out what causes the crash I ended up in
LibreCAD-master/librecad/src/lib/math/lc_quadratic.cpp
at the line 416
return getIntersection(p1->flipXY(),p2->flipXY()).flipXY();
this line calls
LC_Quadratic LC_Quadratic::flipXY(void) const
and in here, a new LC_Quadratic object is created
LC_Quadratic qf(*this);
the problem is the above line calls the copyconstructor and it seems like the constructor
does not copy/create the m_mQuad attribute when the old m_mQuad is not quadratic ->size of m_mQuad is 0!!!! .
that's no problem until the line 422 (in lc_quadratic.cpp)
fabs(p2->m_mQuad(0,0))<RS_TOLERANCE && fabs(p2->m_mQuad(0,1))<RS_TOLERANCE
in RS_VectorSolutions LC_Quadratic::getIntersection(const LC_Quadratic& l1, const LC_Quadratic& l2)
because the size of m_mQuad is 0, boost throws an exception and LCAD crashes.
Re: [Bug] rs_actiondrawellipsecenter3point
nice job!
I remember the LC_Quadratic is based on boost stuff, might be the reason.
Can you fix this (and go ahead to review the LC_Quadratic class)?
I moved all getIntersection() methods to be based on quadratic. so removed logic like:
if ( line && circle) getIntersectionLineCircle();
if ( circle && circle) getIntersectionCircleCircle();
etc.
cantcode
well,
I tried to "fix" that but got even more errors :)
I think I have not enough knowledge to make a good fix. So if someone want to do this, he/she can do that.
I will try to "fix" this and tell what I find out.
But I guess before I can "fix" this I will have to ask dozens of questions first ;) cause I just started pocking in the code and don't understand a lot.
It's a mistake in line 383 of lc_quadratic.cpp RS_VectorSolutions LC_Quadratic::getIntersection(const LC_Quadratic& l1, const LC_Quadratic& l2);
We only go ahead to find intersections when both quadratic forms are valid.
I pushed the fix to master branch, commit: fb5712b
The steps to reproduce the crash:
0, enable snap to grid only.
1, start draw ellipse by center and 3 points;
2, choose any center;
3, choose another point at one grid point as the first point;
4, when proposed to choose the second point, move to the same grid point chosen in step 3.
Results: LibreCAD crashes.
a patch to fix it:
diff --git a/librecad/src/lib/math/lc_quadratic.cpp b/librecad/src/lib/math/lc_quadratic.cpp
index 7c5712b..1dcf78a 100644
--- a/librecad/src/lib/math/lc_quadratic.cpp
+++ b/librecad/src/lib/math/lc_quadratic.cpp
@@ -380,7 +380,7 @@ LC_Quadratic LC_Quadratic::flipXY(void) const
     RS_VectorSolutions ret;
-    if( (l1.isValid() && l2.isValid()) == false ) {
+    if( (l1.isValid()==false && l2.isValid()) == false ) {
 //        DEBUG_HEADER();
 //        std::cout<<l1<<std::endl;
 //        std::cout<<l2<<std::endl;
cantcode
now that was fast.
thanks for telling the reason, so I can have a look at it and try to understand.
Well at least I was in the same file when searching the bug ;)
Just make sure you don't miss this commit:
https://github.com/LibreCAD/LibreCAD/commit/f2b089680b7ccf9f849a894a4feaf94b0800c81f
-    if( (l1.isValid()==false && l2.isValid()) == false ) {
+    if( (l1.isValid()==false || l2.isValid()) == false ) {
The logic is clear: do not do intersection if any quadratic is invalid.
cantcode
"-    if( (l1.isValid()==false && l2.isValid()) == false ) {
+    if( (l1.isValid()==false || l2.isValid()) == false ) { "
I think there is a bracket missing or there are too much of them.
trying to fix this bracket issue, I still get a crash.
will try to investigate a litte more.
Maybe you are right,
you can try this
    if( (l1.isValid()==false || l2.isValid()==false ) ) {
or this
    if( l1.isValid()==false || l2.isValid()==false ) {
If this doesn't help, I must have a look at the source file myself.
You are right!
it should read:
if( l1.isValid()==false ||  || l2.isValid()==false ) {
my bad again :(
Thanks a lot to point out
Dongxu
On Fri, Jun 14, 2013 at 1:22 PM, cantcode [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/Bug-rs-actiondrawellipsecenter3point-tp5708194p5708348.html
Dongxu Li, Ph.D.
www.librecad.org
I still get a crash:
0, start LibreCAD with empty drawing;
1, start drawing ellipse with center and 3 points;
2, select only "snap by grid" in snap toolbar;
3, select center a center at: 100, 100;
4, select the first point at @100, 10;
5, move mouse point to make snap point for the second point at @80, 10;
results:
LibreCAD crashes.
you can try this
or this
OK, I will sneak a peek at it.
it's a tolerance issue.
to test whether a double is zero, the broken test is:
foo < 1.e-20
looks like it's more reasonable to do:
foo < 1.5e-15
if this happens again, we increase it further
commit 5ecbc49891f81dc76eebd13742e4c4f23911b368
Well done!
I reproduced the crash as you described with the previous version.
With your new commit it is OK.
cantcode
1 post
can someone pleasse tell me why we have to square the vector??
"if( (sol.get(mSize) - sol.get(mSize-1)).squared() < RS_TOLERANCE15 ) {..."
so we take the last two vectors and subtract them to get a new vector.
why do we then use .squared afterwards?
Isn't the  RS_TOLERANCE15 the length which tells us if we should consider the next point as a new one?
If so, then one would have to calculate the length of the new vector (coming from the subtraction).
IIRC, the length of a vector is calculated by squaring the x,y,z components, adding them and then square root the result.
actually, squared() is a misnomer here. It should be called squaredLength() or lengthSquared():
for a 2D vector, RS_Vector( x, y);
double RS_Vector::squared() const {
        return x*x + y*y;
we use squared length instead of length when we only need to compare length, so, we skip the extra sqrt() here.
On Sat, Jun 15, 2013 at 4:34 PM, cantcode [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/Bug-rs-actiondrawellipsecenter3point-tp5708194p5708359.html
Dongxu Li, Ph.D.
www.librecad.org
