Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hey guys cause I would like to learn how to code, I was trying to find the cause of a bug.
When drawing an ellipse from the center and three points (rs_actiondrawellipsecenter3points) there seems to be a bug. Trying to figure out what causes the crash I ended up in LibreCAD-master/librecad/src/lib/math/lc_quadratic.cpp at the line 416 return getIntersection(p1->flipXY(),p2->flipXY()).flipXY(); this line calls LC_Quadratic LC_Quadratic::flipXY(void) const and in here, a new LC_Quadratic object is created LC_Quadratic qf(*this); the problem is the above line calls the copyconstructor and it seems like the constructor does not copy/create the m_mQuad attribute when the old m_mQuad is not quadratic ->size of m_mQuad is 0!!!! . that's no problem until the line 422 (in lc_quadratic.cpp) fabs(p2->m_mQuad(0,0))<RS_TOLERANCE && fabs(p2->m_mQuad(0,1))<RS_TOLERANCE in RS_VectorSolutions LC_Quadratic::getIntersection(const LC_Quadratic& l1, const LC_Quadratic& l2) because the size of m_mQuad is 0, boost throws an exception and LCAD crashes. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
nice job!
I remember the LC_Quadratic is based on boost stuff, might be the reason. Can you fix this (and go ahead to review the LC_Quadratic class)? I moved all getIntersection() methods to be based on quadratic. so removed logic like: if ( line && circle) getIntersectionLineCircle(); if ( circle && circle) getIntersectionCircleCircle(); etc. |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
well,
I tried to "fix" that but got even more errors :) I think I have not enough knowledge to make a good fix. So if someone want to do this, he/she can do that. I will try to "fix" this and tell what I find out. But I guess before I can "fix" this I will have to ask dozens of questions first ;) cause I just started pocking in the code and don't understand a lot. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
It's a mistake in line 383 of lc_quadratic.cpp RS_VectorSolutions LC_Quadratic::getIntersection(const LC_Quadratic& l1, const LC_Quadratic& l2); We only go ahead to find intersections when both quadratic forms are valid. I pushed the fix to master branch, commit: fb5712b The steps to reproduce the crash: 0, enable snap to grid only. 1, start draw ellipse by center and 3 points; 2, choose any center; 3, choose another point at one grid point as the first point; 4, when proposed to choose the second point, move to the same grid point chosen in step 3. Results: LibreCAD crashes. a patch to fix it: diff --git a/librecad/src/lib/math/lc_quadratic.cpp b/librecad/src/lib/math/lc_quadratic.cpp index 7c5712b..1dcf78a 100644 --- a/librecad/src/lib/math/lc_quadratic.cpp +++ b/librecad/src/lib/math/lc_quadratic.cpp @@ -380,7 +380,7 @@ LC_Quadratic LC_Quadratic::flipXY(void) const RS_VectorSolutions LC_Quadratic::getIntersection(const LC_Quadratic& l1, const LC_Quadratic& l2) { RS_VectorSolutions ret; - if( (l1.isValid() && l2.isValid()) == false ) { + if( (l1.isValid()==false && l2.isValid()) == false ) { // DEBUG_HEADER(); // std::cout<<l1<<std::endl; // std::cout<<l2<<std::endl; |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
now that was fast.
thanks for telling the reason, so I can have a look at it and try to understand. Well at least I was in the same file when searching the bug ;) |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Just make sure you don't miss this commit:
https://github.com/LibreCAD/LibreCAD/commit/f2b089680b7ccf9f849a894a4feaf94b0800c81f - if( (l1.isValid()==false && l2.isValid()) == false ) { + if( (l1.isValid()==false || l2.isValid()) == false ) { The logic is clear: do not do intersection if any quadratic is invalid. |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
"- if( (l1.isValid()==false && l2.isValid()) == false ) {
+ if( (l1.isValid()==false || l2.isValid()) == false ) { " I think there is a bracket missing or there are too much of them. trying to fix this bracket issue, I still get a crash. will try to investigate a litte more. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Maybe you are right,
you can try this if( (l1.isValid()==false || l2.isValid()==false ) ) { or this if( l1.isValid()==false || l2.isValid()==false ) { If this doesn't help, I must have a look at the source file myself. Armin
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
You are right! it should read: if( l1.isValid()==false || || l2.isValid()==false ) { my bad again :( Thanks a lot to point out
Dongxu
On Fri, Jun 14, 2013 at 1:22 PM, cantcode [via LibreCAD] <[hidden email]> wrote:
Dongxu Li, Ph.D. www.librecad.org |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I still get a crash:
0, start LibreCAD with empty drawing; 1, start drawing ellipse with center and 3 points; 2, select only "snap by grid" in snap toolbar; 3, select center a center at: 100, 100; 4, select the first point at @100, 10; 5, move mouse point to make snap point for the second point at @80, 10; results: LibreCAD crashes.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
OK, I will sneak a peek at it.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
it's a tolerance issue.
to test whether a double is zero, the broken test is: foo < 1.e-20 looks like it's more reasonable to do: foo < 1.5e-15 if this happens again, we increase it further commit 5ecbc49891f81dc76eebd13742e4c4f23911b368 |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Well done!
I reproduced the crash as you described with the previous version. With your new commit it is OK. Armin
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
can someone pleasse tell me why we have to square the vector??
"if( (sol.get(mSize) - sol.get(mSize-1)).squared() < RS_TOLERANCE15 ) {..." so we take the last two vectors and subtract them to get a new vector. why do we then use .squared afterwards? Isn't the RS_TOLERANCE15 the length which tells us if we should consider the next point as a new one? If so, then one would have to calculate the length of the new vector (coming from the subtraction). IIRC, the length of a vector is calculated by squaring the x,y,z components, adding them and then square root the result. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
actually, squared() is a misnomer here. It should be called squaredLength() or lengthSquared():
for a 2D vector, RS_Vector( x, y); double RS_Vector::squared() const { return x*x + y*y; } we use squared length instead of length when we only need to compare length, so, we skip the extra sqrt() here.
On Sat, Jun 15, 2013 at 4:34 PM, cantcode [via LibreCAD] <[hidden email]> wrote: can someone pleasse tell me why we have to square the vector?? ... [show rest of quote] Dongxu Li, Ph.D. www.librecad.org |
